Is it possible to create a skin that would preload modules that contain pre-loaded data.
The idea is for my distibutors to pick skins that concentrate on the part of my product line that most interests them.
Thank you
Hi Mark,
As far as I know, this is not possible. But, it is possible for you to create a portal template which a user could load using the site wizard. This would pre-load modules, skins and data that you specify.
I've just created a tutorial on this for issue 17 which i am currently in the middle of releasing, but in the meantime, you can view the tutorial here:
DotNetNuke Portal Templates and the Site Wizard
