If you want to only move the roles, and nothing associated with the users, you might try:
- make a copy of the site
- delete all of the pages and all of the users
- delete most of the modules and skins
- export the site
You can then import the site to your new site, and mostly all that should be imported is the roles. You could manually edit the export to eliminate other things that you don't want imported.
You might want to do this early on, before adding other stuff to the site.
Mind you, this is off the top of my head, so you may need to experiment a bit to get it to do what you want it to do.
