You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Announcements
DotNetNuke 5.2.3 Released
Last Post 02/19/2010 2:57 AM by
. 0 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
02/19/2010 2:57 AM
DotNetNuke 5.2.3 has been released:
Major Highlights
Fixed the issue where LinkClick.aspx links were incorrect for child portals
Fixed the issue with the PayPal URL settings.
Fixed the issue with logging into the site on 1st page load after upgrade.
Fixed issue where hosted jQuery did not use the correct protocol when SSL enabled.
Fixed issue with inconsistent file/folder permissions tests. Test now runs when the page is shown and user cannot progress until tests p .
Fixed the issue with the SynchronizeModule in all install modes causing an object reference error.
Fixed issue where captcha control showed after succesful registration if the SMTP settings were not correct
Fixed issue where error message failed to display if control was not created
Fixed the issue where the Portal name was hard coded as 'PortalName' when igning modules to portals.
Fixed issue where security roles were not properly enforced between child portals.
Fixed issue where large/javascript heavy pages could suffer from an MS Ajax DeserializePrimitiveObject Invocation error
Fixed issue where the user is unable to change dbowner in the install wizard.
Fixed issue where spaces in control names caused error in new module control wizard
Fixed issue with allowing a blank database name in Installation Wizard.
Fixed the issue where the www. subdomain of a domain is not part of the portal aliases of a portal
Fixed issue where the Parent Tab was not showing in drop down if the user had no edit rights on it.
Fixed issue where list values in profile properties only work on Portal with PortalID=0
Fixed issue when unzipping files in the Host File Manager
Fixed issue where module message warning was not XHTML compliant
Fixed the issue where sometimes there were event log errors during installation from importing HTML modules.
Fixed issue where installer feedback was not using p ed parameter to output feeback messages
Fixed issue with custom name space in Starter Kits.
Fixed issue where errors were logged during automated installs.
Enhanced create new module form to split file language and file name onto seperate lines, and updated help text
Fixed missing objectqualifer in dataprovider script which could fail to update installs without a default language
Updated data provider reference to use fully qualified typename which could cause compilation issues with third party modules in some rare instances.
Fixed validation error handling in new module wizard
Updated text on create new module screen to clarify that make new folder is only available on "New" option
Fixed issue where it was possible to create a module with a name or friendlyname the same as an existing package
Fixed issue where invalid control name could crash New Module wizard
Fixed the validation of Module Control Name when creating a new module manually.
Enhanced New Module wizard to make friendly name a required field.
When using the create new module you can specify a control with spaces e.g. "my control". Whilst this is valid for a control definition, as that is used to create the file and also the inherits statement an error is caused as neither of support spaces. To resolve we added code to remove spaces from control names as they're not allowed.
Modified Install Wizard so that all tests must p before installtion may proceed. Tests are conducted either on entering the page or on clicking the Next button.
Updated layout and help text of the "Create New Module" form and added some code to remove spaces from module names to ensure only valid files are created.
Added the ability to use the PayPal sandbox for validating PayPal configuration
Security Fixes
User account escalation Vulnerability
Updated Modules/Providers
The following modules and providers have been updated in the 5.2.0 packages.
Please see the specific project pages for notes on what bugs or enhancements
were corrected with each release.
Modules
Events Module 05.00.03
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Announcements
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
