You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
Module Dropdownmenu seperator
Last Post 02/15/2010 3:25 PM by
TommyOnDNN
. 8 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
TommyOnDNN
02/15/2010 2:07 PM
Hey All, I'm using an Artisteer generated skin and my Module-dropdown-menu seperator is way to high, which causes me to be unable to select certain dropdownmenu options, such as "delete". Doe anybody happen to know how to fix this?
02/15/2010 2:16 PM
I haven't used Artisteer, but in theory it should be setup the same as a standard skin.
I'm not sure what you mean, from looking at the picture, Delete looks selectable, could you provide further info?
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
TommyOnDNN
02/15/2010 2:20 PM
Well, I figured using the Artisteer skin messed something up in the CSS, which causes the Module dropdown seperators to be much higher as usual.
In this instance (screenshot) all dropdown menu items are selectable, however often the bottom menu items are not. So I figured fixing the CSS value that causes the seperators to be as high as they are, would solve the problem. Don't have a clue on where to start looking for that CSS key though.
02/15/2010 2:27 PM
ok, simplest way for you to troubleshoot and find the CSS code to change will be to use the techniques in this tutorial:
Using the techniques there I would recommend that in the web develeoper toolbar you delete all of the CSS and then introduce elements of the CSS until you find the section of CSS that is causing the problem.
Depending on their CSS class names, you may need to look for code related to:
/* Module Title Menu */
.ModuleTitle_MenuContainer
etc.
DotNetNuke Podcasts
Twitter:
TommyOnDNN
02/15/2010 2:38 PM
Thanks Lee!
Haven't solved the problem yet, however this tutorial will be way more benificial troubleshooting these kinds of errors in the future.
TommyOnDNN
02/15/2010 3:00 PM
Ok, I've managed to find the CSS value in the DEFAULT.CSS file which controls the menu break:
.ModuleTitle_MenuBreak
border-bottom: #EEEEEE 1px solid;
border-left: #EEEEEE 0px solid;
border-top: #EEEEEE 1px solid;
border-right: #EEEEEE 0px solid;
background-color: #EEEEEE;
height: 1px;
However it is already set to 1px. Changing the value doesn't affect the seperator styling, except for changing it to huge values (100px for instance) which does increase the seperator's height.
I've searched through all of the CSS and can't find another key called ".ModuleTitle_MenuBreak", which could possibly overwrite the ".ModuleTitle_MenuBreak" in DEFAULT.CSS.
When I tried "Information > Display ID & Class" from the web developers toolbar, I found the menubreak seperator has the following ID:
#dnn_ctrl406_dnnACTIONS_cltdnnACTIONSctr .ModuleTitle_MenuBreak break mi mi0-6 id
which doesn't make much sense to me. Probably because the dropdown menu is dynamic.
How do you recommend I proceed, fixing the seperator height?
02/15/2010 3:05 PM
In the web developer toolbar try deleting all content from all of the CSS files except for the default.css file - all of the skin styling will be removed, but does the module menu now display correctly?
DotNetNuke Podcasts
Twitter:
TommyOnDNN
02/15/2010 3:06 PM
Sorry, posted to quickly.
it was:
.ModuleTitle_MenuIcon
cursor: pointer;
border-left: #EEEEEE 1px solid;
text-align: center;
width: 15px;
height: 21px;
When I adjust the height to 1px everything is fine.
Don't really understand how the skin could alter this value, since the skin, which is installed using the Administrator Menu (Portals\0\Skins\SKIN) shouldn't alter the DEFAULT.CSS should it?
TommyOnDNN
02/15/2010 3:25 PM
Sorry,
I've been being too hasty. It's the style.css, not the default.css that messes things up.
The seperator size does get fixed when altering the heigh from 21px to 1px, however the menu still doesn't display correctly.
I just found it is the a key in the STYLE.CSS, namely:
/* begin LayoutCell */
.art-contentLayout .art-sidebar1
position: relative;
margin: 0;
padding: 0;
border: 0;
float: left;
overflow: hidden;
width: 201px;
/* end LayoutCell */
When I delete the "position: relative;" value, the menu displays correctly again. Don't know if I'm breaking something else by deleting that line though.
However thanks for pointing me in the right direction on troubleshooting these problems. Very valueable.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
