Hello Joe,
thanks for your immediate reply.
Yes I have something in mind that I'd like to do. It's about displaying data of our photovoltaic-installations.
I need one form to display the general data of the installation such as adress, geographic location, pitch of the roof and things of that nature.
This is in the 1-Table. The n table holds information about the energy yield of the systems. I want to be able to display the daily, the monthly and the yearly data on a kind of tab-form.
On top of that it would be nice to have the opportunity to show the data in bar-graph charts with a drill-down function. That means you show for instance the data of a year on one chart, than you click on - let's say the month april - and you get the monthly data for april of that year.
I' m sure there are several way's to realize that but I've not the expierience to figure out which one is the most flexible and extensible.
The charts shoud be something like that:
DotnetchartingIs there any dnn module that uses dotnetcharting ?
Thanks for any ideas ...
