i've added the necessary entries to my skin.css and fckstyles.xml file as shown in the tutorial. imageleftside and imagerightside work as shown in the tutorial. The quoteleft, quoteright, imagerightsidecaption, imageleftsidecaption styles are giving me trouble, however.For example, I paste some plain text to test with. if i select a section of this text and use the quoteleft or quoteright, it puts the entire text i pasted into the quoteleft,quoteright. why isn't it just putting the text I select as the quote instead of the entire paragraph ? Same thing happens with the imagerightsidecaption and imageleftsidecaption - i select the image and a few words of text and it formats the entire paragraph. The style is applied to everything between the starting/ending paragraph tags and the paragraph tags are replaced by the div tags. Any ideas as to what i need to do to fix this? thanks!
