.containerwrapper_lifeplus{ width: 100%; background-color: Transparent; margin-top:5px.containeheader_lifeplus { background-color: #27408B; text-align: center; vertical-align: middle; min-height: 30px; margin-top:15px; Following along with classes. I am trying to get the text in the header section to display in the center, both horizontally and vertically. It currently displays center horizontally but at the top of the header section not the middle? I thought that might need to be indicated in the skin css but that appeare to be for font style only, not postioning. (though I did try adding the vertical-align:middle to in the module header style section, without effect.
Thank you for any help
Hi Mark,
I've just had a look in one of my CSS skins. If vertical-align is not consistant I would use padding.
Something like:
padding: 15px 0;
This will add padding to the top and bottom of the title and will therefore centre it in its own space.
Does this help?
