You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Asp roles in Sql Server Express
Last Post 12/22/2009 10:13 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
John Kirkman
12/20/2009 4:39 PM
I have sql server 2005 installed on two different machines. On one of them under Databases/Databasename/Roles/Database Roles there are several ASPNET_ roles and on the other machine the ASP roles are not listed. How do I add ASPNet roles to Sql Server Express 2005? Any help would be greatly appreciated.
John
12/21/2009 2:25 AM
In SQL Server Management Studio
Go to the Security folder / logins
Right click on logins and select new login
For Login name click on the search box
Click on advanced
Click on find now
are from there you can select any ASP.NET roles that you require
That will make those logins available to any database, to then add them to a database:
expand a database node
expand the security folder / roles
You can then add a row into the database by right clicking on the roles folder
I think it will cover what you need, all I usually do is add a username for accessing the database using that method - in the past I have not needed to add ASP.NET roles - let us know if this helps, thanks,
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
John Kirkman
12/21/2009 7:21 AM
Lee,
Thanks for your response. From the
folder / logins /add new login the only ASP option I have is ASPNET which I added to a new user. Then from the MyDatabase/Security/Users the only options I have for roles are db_accessadmin, db_owner, etc. I do not have any ASPNET_Membership, ASPNET_Profile or ASPNET_Roles options.
I had SQL express 2008 installed on this machine and removed it and added SQL Express 2005. This is a new install of SQL Express 2005. Did I forget to check something with the install?
Many thank,
John
12/22/2009 10:13 AM
Why did you go from 2008 to 2005? 2008 should work fine with DNN. Something may have happened in the switch from one version to another.
I'm not sure what to suggest, I would be tempted to install SQL 2008 Express - but make sure you install the full version with advanced services. For info on this check out how I installed it with this tutorial:
How to install DotNetNuke to Windows 7
If you are working on a local computer, I would also suggest you use a Virtual PC, it makes it much easier for managing DNN configurations:
How to setup and use Microsoft Virtual PC 2007
DotNetNuke Podcasts
Twitter:
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
