and in the latest version that I have (1.3.3) all seem to have been fixed except for Red errrors constantly showing (which is cosmetic).The only cons I have so far are:a. you cannot add the source version of the module using DNN4 as you get an error message. You have to add the PA version and that works fine. I have not yet tried compiling the source under DNN4 but I suspect it may need hand-tailoring first.b. the sorting of projects is limited - sort order or reverse sort order, selectable by admin only. It would be nice to offer sort by date created, project date, etc and make this sort user-selectable.but in all a very flexible module John B
