You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Child pages not following parent page moves
Last Post 11/13/2009 6:40 PM by
Steve
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Steve
11/11/2009 3:47 PM
I posted this issue in the dnn forums, but haven't gotten any kind of answer. Thought maybe someone here might have an idea. The site I'm working on has about 500 pages currently, and we're in the process of building about 3300 total pages. Midway through the proces of adding pages, it was decided that we needed to alter the directory sheme a bit. We went from domain.com/counties/pages.aspx to domain.com/states/counties/pages.aspx. When we made the change, the child pages did not follow the parent pages. The pages could still be found at domain.com/counties/pages.aspx even though the counties page had become a child of the state pages. This also happened in reverse, when we reassigned parent pages to another location then deleted the previous page. The only workaround that I've found, if you can call it a workaround, is to manually 'update' each child page, ie go to each pages settings, click update, and the page then finds the parent correctly. This seems like a pretty serious bug for large sites. :-( If it is a bug, does anyone know of a way to force the database to reindex the pages? I think Ifinity's URL master might do this, and we'll probably end up using it anyway, but I don't have enough in my budget for this site to purchase the license yet. Any insight or suggestions would be very welcome!
DNN MVP
11/12/2009 5:53 AM
What you describe is certainly not the correct behavior, and I cannot reproduce it on my 5.1.4 test site.
With the large number of pages that you have, it might be easier to organize/reorganize the pages using SQL queries. You can get an introduction by viewing
Introduction to SQL Queries with SQL Server Express, DotNetNuke and Vista
How to Update the DotNetNuke Page Settings Using SQL Queries
The page heirarchy is contained in the Tabs table. Fields that you will want to look at are TabOrder, Level, ParentID and TabPath.
If you decide to go this way, be sure to make a backup copy of your database first.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Steve
11/13/2009 6:40 PM
Thanks Joe. At least I know it's a localized problem and not something that is systemic to dnn. I can't for the life of me figure out why this would happen. It's occurred on two different installs, both completely clean installs of dnn 5.1.x with no other modules installed. I'll dig into those sql tutorials and see if I can at least deal with the problem at hand that way while I work with my host for a permanent solution.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
