You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
layout error in IE for DNN 5.1
Last Post 11/04/2009 1:43 PM by
Lillian
. 7 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Lillian
11/03/2009 2:21 PM
So i'm using 5.1 and i have leftpane, contentpane, and rightpane. leftpane has third level snapsis menu in it. I also added DNNEmptypane class in my skin. When i test this in firefox, i have no problem, but in IE, the contentpane does not stretch out to fill the page. do I have to use any hacks for IE? or is this CSS issue? I'm using same css for DNN 4 and it works.. so i'm guessing its DNN 5.1 issue?
DNN MVP
11/04/2009 5:43 AM
Which version of IE is this? If it is IE8, try clicking the compatibility button to see if that makes the issue go away. If so, you can add a meta tag to your site to force IE8 to render it in compatibility mode, until DNN gets adjusted to work with IE8.
Joe Craig,
Patapsco Research Group
Complete DNN Support
DNN MVP
11/04/2009 5:44 AM
One more thing that you can do is look at the same pages with the Minimal Extropy skin applied. If that skin works, compare your css with that css to see if you can identify differences.
Joe Craig,
Lillian
11/04/2009 9:36 AM
Its actually IE7. and i want to try to install minimal extropy skin, but when I opened the folder, it had two index files. one called index and the other called index full. what is the difference and which ones should I zip to install
DNN MVP
11/04/2009 9:42 AM
If you want to use the Minimal Extropy skin, it should have autoinstalled, and you can choose between the two files when you pick a skin. I think that index is not full screen, whereas indexfull is.
Joe Craig,
Lillian
11/04/2009 11:36 AM
thanks, now when I used the minimal extropy skin, I couldnt really test it since layout is completely different. Just can't figure it out. why it works fine with DNN 4 and not 5.1. also fact that it works in firefox but not IE. I'm lost
DNN MVP
11/04/2009 11:38 AM
I understand. Attach your skin file and css file to your reply and maybe we can look it over.
Joe Craig,
Lillian
11/04/2009 1:43 PM
That would be awesome! you must add third level menus to test it. Thank you so much.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
