Hi Lee
I understand that you use Flash to display your video's for Dnncreative tutorials. But what software do you use to capture the actions of your computer screen and narriation prior to inserting it into Flash?
Lynn
Just a suggestion, but I use Wink for creating flash tutorials. I'm sure it's no where near as robust as Captive but it is free and it does a good job
http://www.debugmode.com/wink/
