Hi Lynn,
I've created a tutorial for the next issue which tells you exactly how to find out the classes for styling any elements on your page:
http://www.dnncreative.com/Tutorial...fault.aspx
The edit text is styled with the class: .CommandButton
I'm not sure about the pencil icon. - This looks as though you can only style it using the styling for the img tag:
ie:
padding: 0;
border: 1px solid orange;
But this styles all images in the skin.
You could focus it a bit further by combining an id of a container ie: in the DNN Blue skin:
.containermaster_blue img
padding: 0;
This will add an orange border around all images in the blue container.
If you place a div id around the edit pencil token area in your container, you could then specify the id and then img tag and just style the pencil token.
Hope this makes sense, thanks,
