Thanks --- Here's the dump of the event causing the critical error -- Please advise...
AssemblyVersion: 5.0.1
PortalID: 0
PortalName: Radhasoami Faith Sample Website Design
UserID: 1
UserName: host
ActiveTabID: 18
ActiveTabName: Module Definitions
RawURL: /RSFaithSample/tabid/18/ctl/Edit/mid/348/PackageID/84/portalid/0/Default.aspx
AbsoluteURL: /RSFaithSample/Default.aspx
AbsoluteURLReferrer:
http://realview.mysite4now.net/RSFa...fault.aspx UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.3) Gecko/20090824 Firefox/3.5.3 (.NET CLR 3.5.30729)
ExceptionGUID: 9e356d3c-46e7-49e9-8900-2425cfd6606a
InnerException: Object reference not set to an instance of an object.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: DotNetNuke.Security.Permissions.Controls.PermissionsGrid.GetUsers
StackTrace:
Message: DotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object.
---> System.NullReferenceException: Object reference not set to an instance of an object.
at DotNetNuke.Security.Permissions.Controls.PermissionsGrid.GetUsers() at DotNetNuke.Security.Permissions.Controls.PermissionsGrid.CreateChildControls()
at System.Web.UI.Control.EnsureChildControls()
at System.Web.UI.Control.FindControl(String id, Int32 pathOffset)
at System.Web.UI.Control.FindControl(String id)
at ASP.portals__default_containers_rsfsamplednnskin20090922v2_block_ascx.ReplaceHelpIcon(Control ctl)
at ASP.portals__default_containers_rsfsamplednnskin20090922v2_block_ascx.Page_PreRender(Object sender, EventArgs e)
at System.Web.UI.Control.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
--- End of inner exception stack trace ---
Source:
Server Name: DEDI243
