www.dignuke.com
Mike
Nice clean looking skin!
The digiRotate module looks nice too! Looking forward to see what other modules you create
All the digRotage (Front Page & Demos) rotation work for me in IE 6.0.2900.2180. I'll try 7.0 when I get home tonight.
Thanks for your help everyone!
Lee, can you think of anything that might make your IE differenet? Are you running any Virus software or ad blockers? Localized version of XP or IE? I tried it on several IE6/XP machines with no problems. I even tried that browsershots site that you mentioned in another post, and it just so happened that the timing was right on the IE6 and it displayed the 2nd graphic on the front page cleanlly.
I disabled the scrolling on http://www.dignuke.com/Modules/digR...fault.aspx
Does that make a difference for you?
Thanks for any help!
