You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Portal Creation
Last Post 09/15/2009 10:29 PM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
tierautos
09/15/2009 8:04 AM
I want to create portals from a single website in which all modules are replicated to each new portal. I have many 3rd party modules such as Mandeeps and Onyaktech. It's not clear to me why I can't just create the new portal and go with the modules all intact on the new portal, but, it's clear it doesn't happen as desired. Short of that, what is the "next best solution" to this. Does creating the portal as a "parent" help? Does creating a template of the source WITH content work? Mandeep modules allow for import/export but it's "incomplete" in that it won't import "element" images (those to be "clicked on") My original site is fine; it's just the problem with "parent/child portal creation" that has to be "jury rigged" to bring as much content as possible across to the new parent or child portal that has me concerned. I top-down list of remedies would be really helpful. Thanks, Ray Myers
DNN MVP
09/15/2009 8:12 AM
When you create a new portal, all of your installed modules should be available to you. If you are talking about module content, that is different. The basic design of DotNetNuke is to support multiple portals, but generally portals are intended to be separate (content wise) from one another. There are modules that will help share content across portals within a single install. Is that your question?
Joe Craig,
Patapsco Research Group
Complete DNN Support
tierautos
09/15/2009 8:38 AM
Thanks, Joseph. The application is meant to give each portal the same set of tools. Go here to see what I mean:
http://www.tierautos.com/jimspearsauto.
This link represents the template from which all other portals will spawn. That said, the more intact content I can bring across, the less time I spend having to "tweak" the newly-copied(?) modules in the spawned site. Where jimspearsauto is to be one of many used car dealers using the same set of available services (modules turned "on" or "off"). So, josephcraigmotors would have the same modules available across the child/subportal spectrum. In other words, each used car dealer is given the same tool (skins, modules, rights, etc.). All admin is done by www.tierautos.com. Ray
DNN MVP
09/15/2009 10:29 PM
This might be a case where you want to create a portal template with some preconfigured content. You'll want to check
DotNetNuke Portal Templates and the Site Wizard
Managing and Configuring Portals as a Host Super User
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
