New Install; no install errors; working great. Attempted to update the Admin Site Settings and received an error. Went back and attempted to select 'Update' without changing anything and still received the error below:
Error: Site Settings is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Cannot insert the value NULL into column 'DefaultLanguage', table '(actualdomainnameremoved).dbo.Portals'; column does not allow nulls. UPDATE fails. The statement has been terminated. ---> System.Data.SqlClient.SqlException: Cannot insert the value NULL into column 'DefaultLanguage', table '(actualdomainnameremoved).dbo.Portals'; column does not allow nulls. UPDATE fails. The statement has been terminated. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteNonQuery(SqlConnection connection, CommandType commandType, String commandText, SqlParameter[] commandParameters) at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteNonQuery(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteNonQuery(String connectionString, String spName, Object[] parameterValues) at DotNetNuke.Data.SqlDataProvider.UpdatePortalInfo(Int32 PortalId, String PortalName, String LogoFile, String FooterText, DateTime ExpiryDate, Int32 UserRegistration, Int32 BannerAdvertising, String Currency, Int32 AdministratorId, Double HostFee, Double HostSpace, Int32 PageQuota, Int32 UserQuota, String PaymentProcessor, String ProcessorUserId, String ProcessorPassword, String Description, String KeyWords, String BackgroundFile, Int32 SiteLogHistory, Int32 SplashTabId, Int32 HomeTabId, Int32 LoginTabId, Int32 UserTabId, String DefaultLanguage, Int32 TimeZoneOffset, String HomeDirectory, Int32 lastModifiedByUserID) at DotNetNuke.Entities.Portals.PortalController.UpdatePortalInfo(Int32 PortalId, String PortalName, String LogoFile, String FooterText, DateTime ExpiryDate, Int32 UserRegistration, Int32 BannerAdvertising, String Currency, Int32 AdministratorId, Double HostFee, Double HostSpace, Int32 PageQuota, Int32 UserQuota, String PaymentProcessor, String ProcessorUserId, String ProcessorPassword, String Description, String KeyWords, String BackgroundFile, Int32 SiteLogHistory, Int32 SplashTabId, Int32 HomeTabId, Int32 LoginTabId, Int32 UserTabId, String DefaultLanguage, Int32 TimeZoneOffset, String HomeDirectory) at DotNetNuke.Modules.Admin.Portals.SiteSettings.cmdUpdate_Click(Object sender, EventArgs e) --- End of inner exception stack trace --- |
