<!--[if gte mso 9]>
Normal
0
unctuationKerning/>
false
false
false
oNotPromoteQF/>
EN-US
X-NONE
X-NONE
ontGrowAutofit/>
ontVertAlignCellWithSp/>
ontBreakConstrainedForcedTables/>
ontVertAlignInTxbx/>
MicrosoftInternetExplorer4
/* Font Definitions */
@font-face
{font-family:"Cambria Math";
panose-1:2 4 5 3 5 4 6 3 2 4;
mso-font-charset:1;
mso-generic-font-family:roman;
mso-font-format:other;
mso-font-pitch:variable;
mso-font-signature:0 0 0 0 0 0;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:-1610611985 1073750139 0 0 159 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:"";
margin-top:0in;
margin-right:0in;
margin-bottom:10.0pt;
margin-left:0in;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:Calibri;
mso-fareast-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;
mso-bidi-language:EN-US;}
p
{mso-style-noshow:yes;
mso-style-priority:99;
mso-margin-top-alt:auto;
margin-right:0in;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
font-family:"Times New Roman","serif";
mso-fareast-font-family:"Times New Roman";}
span.EmailStyle15
{mso-style-type:personal;
mso-ansi-font-size:11.0pt;
mso-bidi-font-size:11.0pt;
color:windowtext;}
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
.MsoPapDefault
line-height:115%;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.0in 1.0in 1.0in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
<!--[if gte mso 10]>
Hi All,
I'm trying to install DNN in a webfarm. I've a Load Balancer device, two web
servers running windows 2003 and one running sql 2005. The application should
only be accessed with https.
When a user request a page eg
https://www.mydomain.com/default.aspx?tabid=36, the load balancer remove the
ssl and redirect the request to one of the web server using
http://webservername:8081/default.a...?tabid=36.
I've only configure two portalalias in the table corresponding the the name
and port of my two web servers :
webserver1:8081
webserver2:8081
I didn'd activate the ssl on the ddn side because my web servers are only
receiving http request from the load balancer.
If i try to get an image eg https://www.mydomain.com/portal/0/logo.gif ->
no problem
If i try a page eg https://www.mydomain.com/default.aspx?tabid=36-> IE
give me 'redirect loop' and ie seems to never end the request
if i try https://www.mydomain.com/keepalive.aspx -> no problem
So apparently my problem is coming from the dnn inside redirection
mechanism. Do you have any idea/ suggestion to solve this blocking issue ?
Thanks for your precious help
Neeraj
