I set my custom profile to display name only once, and I set "Require a Valid Profile for Registration off". When i register I give a FirstName, LastName, Display Name, password. Now if I go to the Profile, the FirstName/LastName are copied over correctly. But, if I change either one of them in the Profile, it does not update the Credential Name, and I end up with two different names in the database, for the same user.
Am I doing something wrong? The names updated correctly in the tutorial, but that was before you eliminated one of the redundant names in the Profile, and you had "Require a Valid Profile for Registration" turned on.
thanks.
