Hi Lee!
Seems like a Bug in the new release!!! 5:1 Installations. See Below.
Here's Stefan Cullmans work around.
This is a core bug, a solution is to set the regex pattern for portal settings.
And here's another solution Stefan Referred me to;
<!--[if gte mso 9]>
Normal
0
unctuationKerning/>
false
false
false
ontGrowAutofit/>
MicrosoftInternetExplorer4
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:36.0pt;
mso-footer-margin:36.0pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
<!--[if gte mso 10]>
I was having similar problems. See http://support.dotnetnuke.com/issue/ViewIssue.aspx?id=10512&PROJID=2.
Try dirtying Admin > User Accounts > User
Settings > Email Address Validation by entering a random character
(say X) and clicking Update, then remove the X and updating.
This resolved the problem for me...
Any ideas Lee?
Will talk further with Stefan and see if I can get around it.
Cheers
Olle...
Back to Issue Filter
Issue 4 of 4605 issue(s)
HyperLink [http://support.dotnetnuke.com/Default.aspx?p=2&i=10512]
Fresh Installation misses some portalsettings
Created:8/2/2009 4:53:07 PM Revised:8/12/2009 1:08:17 PM
Description
I was reported that the data type "email" in Form and List is broken, emails couldn't be saved anymore.
During save, FnL calls DotNetNuke.Services.Email.Email.IsValidEmailAddress.
It turned out that the "Security_EmailValidation" pattern was nothing. I stepped further and noticed that PortalController.GetPortalSettingsDictionary(0) returned only two key/value pairs,, all user related settings were missing.
I am still undecided whether it is an issue of the default portal template.
PS:
If you go to User->User Settings, everything seams to be ok, though it isn't. The editor is initialized with some default values. Even if you hit save, these values are not persisted. The values inside the settingseditorcontrol are not changed, and therefore not dirty.
I needed to explain as work around that users in trouble need to edit the User Adress Validation.
Therefore they need to add a space first, save, edit again and remove the space, and to save again.
Attachments [Add]
Additional Information
Version Reported In (5.1.1) Stabilization Release
Version Fixed In
Public Issue Validated By
Database Platform SQL Express
Operating System < unspecified >
Browser < unspecified >
Development Environment VS.Net 2008
.Net Framework Version .Net 2.0
Fixed in .Net 2.0 Codebase By
Date Fixed In .Net 2.0 Codebase
Verified In .Net 2.0 Codebase By
Date Verified In .Net 2.0 Codebase
Release Notes
Issue Links
None
