I have followed the install instructions
Install DNN 4.8 on Vista to install DNN 5.1.1 on Windows 7. A few detours were necessary, but everything worked well. Thank you very much.
I added some pages with different amounts of test as described in your tutorials. I Installed House of Nuke menu and was ready to install Andreas01. It was late, and I quit for the day.
The next day, I opened
http://localhost/dnn_511" target="_blank" rel="nofollow">
http://localhost/dnn_511 and got the "DotNetNuke Installation Wizard - Welcome" screen.
I tried to install and got an error.
Connection
Error(s):
Index #: 0
Source: .Net SqlClient Data
Provider
Class: 14
Number: 15372
Message: Failed
to generate a user instance of SQL Server due to a failure in starting the
process for the user instance. The connection will be closed.
I deleted C:/DotNetNuke/DNN_511, recreated DNN_511 and copied the downloaded files into it. I went through the turorial again, but I don't remember making any changes to IIS or SQL Experss.
Again the install worked properly, and I rebuilt the site.
Again, I quit for the day, and again, I have the same problem. I opened
I thought that the first time was a fluke, but now I need help.
Gary Minor
