I have done this procedure dozens of time on different machines, but now I am getting “ Login failed for user 'jkirkman'” when I try to browse to the localhost installation of my live web site. The SQL Express 2008 log file says
Login failed for user 'jkirkman'. Reason: An attempt to login using SQL authentication failed. Server is configured for Windows authentication only. [CLIENT: ]
I have spent three days trying to get this to work, could anyone help me.
Thanks,Johon
Joe,Thank you very much for your reply. I am just about to pull my hair out..whats left!I am still having trouble connecting to the database. I have change to mixed modes on SQL Express and am receiving the following error messages:'http://localhost/fumcparistxorg/Install/UnderConstruction.htm" target="_blank" rel="nofollow">http://localhost/fumcparistxorg/Ins...uction.htm
This Site is currently unavailable
"http://localhost/fumcparistxorg/
Login failed for user 'jkirkman'. The latest steps I have done:1. Deleted everything from local machine including database from SQL Express and ISS2. Backed up live site and data base3. Followed tutorial exactally in the order presented4. Actually used your sample web.config file changing database, user and password. Also had to comment out HTML sections.5. Same errors: either Site unavailable or failed to log on.I am sure it is something very simple, but I have not clue where to go.I really appreciate your help.John
TO SQL SERVER EXPRESS
