Can one tell me how i do change the height of left pane.
I want to reduce the height.
Is there any setting for it......PLz help
Here i want to set the height of SubUpperRightPane and SubLowerRightPane.
Normally after adding text in the pane,at the buttom of pane we get some blank space.
I just want to remove that space.Is there any properties for setting height in the above pane.
Or how should i remove that blank space.
