You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
Skin & Containar Installation Problem
Last Post 07/02/2009 2:32 PM by
Tariq Mehmood
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Tariq Mehmood
06/15/2009 10:02 PM
Hi , while installing new skin i am facing this problem.
error log is given blow.
Kindly help me ASAP
Regards,
Tariq
See below for the results of the package installation
Error loading files from temporary folder - see below
StartJob
Starting Installation
Info
Starting Installation - _Skin17-Skin
Info
Starting Installation - Skin
Info
Skin Package Registered successfully - _Skin17
Info
Folder Created - D:\Domains\brasstacks.pk\wwwroot\Portals\_default\Skins\_Skin17\images
Failure
Exception - Access to the path 'D:\Domains\brasstacks.pk\wwwroot\Portals\_default\Skins\_Skin17\images' is denied.
StartJob
Begin Processing of Skin Files
Failure
ExceptionSystem.IO.DirectoryNotFoundException: Could not find a part of the path 'D:\Domains\brasstacks.pk\wwwroot\Portals\_default\Skins\_Skin17\styles\default.css'. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize) at System.IO.StreamReader..ctor(String path) at DotNetNuke.UI.Skins.SkinFileProcessor.SkinFile.Read(String FileName) at DotNetNuke.UI.Skins.SkinFileProcessor.SkinFile..ctor(String SkinRoot, String FileName, XmlDocument SkinAttributes) at DotNetNuke.UI.Skins.SkinFileProcessor.ProcessFile(String FileName, SkinParser ParseOption) at DotNetNuke.Services.Installer.Installers.SkinInstaller.Install()
Failure
Installation Failed - Skin
Info
Installation Failed - _Skin17-Skin
Info
Deleted temporary install folder
EndJob
Installation Failed
DNN MVP
06/16/2009 8:27 AM
This looks like a permissions problem. You will want to check and make sure that your file permissions are set correctly. The default asp user task needs to have full permission for files and folder in the website's directory.
This is from an installation guide written by Mitchel Sellers:
# Right click on your website folder and select "Sharing and Security"
# Switch to the security tab, if you do not see the "Security" tab, you will need to disable the "Use Simple File Sharing" option in your Folder View Options. For assistance with turning off simple file sharing please visit the forums
# Click "Add.."
# In the textbox type ASPNET if on Windows 2000/XP or NETWORK SERVICE if on Windows 2K3/Vista, then press ok
# Under permissions for this account check the box for full control, then press "Ok" to save the changes
Joe Craig,
Patapsco Research Group
Complete DNN Support
Tariq Mehmood
07/02/2009 2:32 PM
Thanks alot , it really did help.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
