You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Membership
flash player will not play the videos
Last Post 12/15/2009 3:13 PM by
Thanh
. 9 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Pierre
06/05/2009 9:31 AM
I just subscribed to this site. When I download a video and unzip it, double click on the icon my page stays blank. I downloaded macromedia flashplayer. I can not find the problem. I did what you suggested to another customer (uninstall, re-install with the latest version, Flash player wii play any other video. I am stuck. thanks.
06/08/2009 6:07 AM
Which browser does this happen in? You may find the security settings in your browser are preventing the play of local flash videos through your browser.
Try lowering the security settings in your browser settings and also try a different browser. It should work ok in IE and Firefox,
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Pierre
06/08/2009 12:00 PM
Hi Thanks for quick answer,
Security is set as low as I can in IE, no more luck. Exactly same response with FIreFOx
06/09/2009 2:44 PM
I'm not sure what would be causing this. I posted some
sugestions here
which may help.
Do you have another computer you could test these on?
Perhaps try installing a new browser and see if that allows the playing of the files - perhaps Google Chrome.
Let me know how you get on,
DotNetNuke Podcasts
Twitter:
Art
06/11/2009 11:06 AM
Hello, Lee
I am also having difficulty viewing the tutorials. I tried your suggestions and lowered security, and changed browsers. I also changed computers and still have the same blank screen.
When I right-click on the screen, I see 2 messages ... "movie not loaded" and "about Adobe Flash Player 10". The movie not loaded is grayed out.
I can see the tutorials you sent in wmv, but not the htm. Can you help with this?
Pierre
06/11/2009 3:42 PM
I tried on 3 other computer and everything worked fine. I finally found a way out by accident; you may laugh but it works. I know it does not make sense but here what happened: with FireFox, If I dblclick the UNZIPPED video file, it starts OK. Does'nt work if I click the unzipped file.
thanks for everything
06/12/2009 10:26 AM
hello,
After a bit of research, I think this is a security setting with the flash player itself, check out this article:
http://www.adobe.com/products/flash...alcontent/
Thinking about it , when flash updated to the latest version 10, I had to change a security setting to allow local flash videos to play.
The info in that article should show you how to update the security settings, let me know if this works, thanks,
DotNetNuke Podcasts
Twitter:
xtg
11/10/2009 9:58 AM
All: Same issue here with IE. Settings cannot go lower than Medium. All we get is that green box in the centre of the screen that says created with Canastia Studio or whatever. The info bar says "Done" and the green box says 100%.
Tried it on Ubuntu Linux 9.10 running Firefox Version 3.5.4, Mozilla Firefox for Ubuntu canonical - 1.0 and it plays audio and video fine. I did notice that any of the tutorials that do not have a sub folder called "Files" play fine in IE. Not sure what this is, but it sounds like permissions to me.
11/17/2009 8:06 AM
thanks for the info
DotNetNuke Podcasts
Twitter:
Thanh
12/15/2009 3:13 PM
I ran into a similar problem on Windows Vista when I tried to open the .htm file directly from the opened WinZip window.
I fixed my problem by EXTRACTING the zipped files to a location. Then I could open the extracted .htm file to view the video without any problem.
Hope this is the same problem some of you might have.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Membership
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
