Hi People - Long time no see?!?!
Now I stuffed up and got the following error on the portal:
www.mepstar.comWhat are the chances of getting to the code and repair?
Error: Site Settings is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Entities.Portals.PortalSettings.GetSiteSettings(Int32 PortalId) at DotNetNuke.Modules.Admin.PortalManagement.SiteSettings.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
Implemented the below code in a TEXT/HTML module, (bottom module on home page.) and then put erroneous DIV tags on it.
Now the website does not open, and I can't enter from
www.bestgoldcoast.com through the portal area.
Thanks for any hints!!!
Olle...
