I noticed a few users having problems with their skins in DNN5.x and HouseMenu, so I've done some testing and found these steps for solving the problem.
First of all, if you are having problems with a skin after upgrading, I would suggest you test out these steps on a fresh DNN5.x install to make sure you can get it to work before testing it on one of your own skins:
Download HouseMenu 1.4 Skin Object from www.houseofnuke.com
Download
Andreas 01First of all install HouseMenu
Go to:
Host / Module Definitions / Install Module
- Install HouseMenu 1.4 Skin Object
Once installed, you need to make a change to the Skin Object, go to:
Host Menu / Extensions
Scroll down to the Skin Objects and click on the 'Edit' pencil icon for HouseMenuSkinObject
You need to change the URL in ControlSrc to:
DesktopModules/housemenuskinobject/HouseMenuSkinObject.ascx
(this will point DNN to the correct folder for the HouseMenu skin object -
Make sure you copy the Capitalisation above)
Click on 'Update Extension' at the bottom of the page
Now you can install the skin, go to:
Host menu / Skins
click on Install New Skin
Browse to the andreas 01 skin zip package
Click Next
It will inform you that it is a legacy skin
Click on the 'Skin' radio button
Click Next
Click Next
Click Next
Tick Accept License, Click Next
The skin and container will install, Click on Return
Now create a new page for a test
Go to the page setting and apply the andreas01 skin and container
All should be working ok
If you have already installed the skin, you will need to re-parse it for the skin to use the correct link to the HouseMenu skin object, to do that, go to:
Host menu / Skins
Click 'Manage Skins'
Select 'Andreas01' from the skins dropdown list
Click on 'Parse Skin Package'
That should solve the problem.
Hope this helps, thanks,
Lee
