Hi Lee
Re issue 11 tutorial: Scalable Inman Flalsh Replacement.
In video 5 you demonstrate how to insert the required Javascript into the Default.aspx file.
However in the Default.aspx file for DNN 4.3.5 the Javascript link code does not seem to be available. I am therefore presuming that DNN are linking to the core javascript folder via another file.
Any suggestions.
Lynn
And if the answer is positive, then how is this affecting other portals within same DNN installation which have no need to implement sIFR ?
