I was playing with adding a site map to my DNN site. Running 4.09.02.
Here is what I did:
- Downloaded the site map module from this link (code project)
http://www.codeproject.com/KB/custo...teMap.aspx- Installed the module
- As per the installation instructions, I added this code to the web.config file
<codeSubDirectories>
<add directoryName="DnnSiteMap"/>
</codeSubDirectories>
Issue: The problem is the site is offline. See the error message at the bottom of this post. It has to do with running both VB and CS code.
I please need to know what I should alter in the web.config file or how to uninstall this module. The problem is I cannot access the site to uninstall it via the interface.
Thank you for your help. This is a hot one.
The files '/App_Code/HTML/HtmlTextInfo.vb' and '/App_Code/DnnSiteMap/ExtendedTreeNode (from Zeus).cs' use a different language, which is not allowed since they need to be compiled together.
Exception Details: System.Web.HttpException: The files '/App_Code/HTML/HtmlTextInfo.vb' and '/App_Code/DnnSiteMap/ExtendedTreeNode (from Zeus).cs' use a different language, which is not allowed since they need to be compiled together.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Stack Trace:
[HttpException (0x80004005): The files '/App_Code/HTML/HtmlTextInfo.vb' and '/App_Code/DnnSiteMap/ExtendedTreeNode (from Zeus).cs' use a different language, which is not allowed since they need to be compiled together.]
System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() +957
System.Web.Compilation.BuildProvidersCompiler.PerformBuild() +29
System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) +384
System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) +125
System.Web.Compilation.BuildManager.CompileCodeDirectories() +525
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +448
System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +57
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +612
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +456
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +3426839
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +88
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +149
