You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Everything Else
FCK Editor Toolbar Not working
Last Post 04/05/2009 9:01 AM by
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
JFranks22
04/04/2009 3:47 AM
I have a weird situation with one of the DNN installations and I would really appreciate some help.
I have two sites - A and B. The FCK Editor Toolbar worked fine in Site A. I copied site A to make Site B. At this point the FCK Editor Toolbar worked fine in both sites - A and B. For some reason, the FCK Editor Toolbar on site A no longer works.
Currently, when I click on Edit Text within any of the Text/HTML modules I am taken to Basic Text Box and the HTML is displayed. However, if you click the Rcih Text Editor, there is nothing displayed whether Source is clicked or not.
The major issue is that when using the Basic Text box I get a lot of
tags that breaks certain elements.
I am not aware of any changes I have made that would cause this.
Is there anyway to reload the files that run the editor?
Thank you VERY much for any advice.
DNN MVP
04/04/2009 7:46 AM
Are sites A and B in a single installation of DotNetNuke, or are they two separate installations?
Are you using a standard DotNetNuke skin, or are you using a custom or purchased skin? If you are not using a standard skin, switch one of the sites to use a standard skin and see if this error continues?
Joe Craig,
Patapsco Research Group
Complete DNN Support
JFranks22
04/04/2009 9:01 AM
Sites A and B are separate installations with their own DB and set of DNN files.
Both sites are using a custom skin.
I switched the skin of Site A (where the editor is not working) to MinimalExtropy and there was no change. I reverted the skin to the original.
Any other thoughts? Thank you again.
DNN MVP
04/04/2009 8:06 PM
AJAX and javascript installed and working? Do all other aspects of DotNetNuke work without problems.
Joe Craig,
JFranks22
04/05/2009 12:14 AM
Everything looked good besides the editor.
I tried resaving the web.config file which did unfortunately not help.
I played some more and changing the editor resolved the issue. From an HTML/Text module:
Edit Text
Show Custom Editor Options
Change Toolbar Skin from Office2003 to Silver and applied these changes to the Portal.
I then changed it back from Silver to Office2003 and the Rich Text Editor is working again!
Thank you.
DNN MVP
04/05/2009 9:01 AM
Well ... glad that it's working!
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Everything Else
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
