Is it possible to change the skins periodically..
Hi joe,
Thanks for reply.
I went through the skin changers provided by snowcovered,but it is not of my requirement...if we use that tool...the end user can see the list of skins in the dropdown menu and he can view the site with the selected skin...'
but my requirement is ,the skin should change automatically along with the period,there should not be any interaction with the end user...
is there any other option..
Thanks in advance
I installed ChameleonSkinChooser module to my application,suddenly when ever i click the admin/skins tab and try to apply the skins selected in the skins combobox,the skin is not applied to the site...
i dont know why suddenly it happened like that..
any one give me suggestion or the solution for this...it's urgent.
thanks in advance
