Hi Lee,
At last i got the solution for that,after these many days..it is very simple....
we need to remove the settings in the container.xml file [ACTIONS] ProviderName DNNMenuNavigationProvider ExpandDepth 1 PopulateNodesFromClient True
then it will work fine
