Hello, Still a newbie to DNN and not sure if this question even belongs in this section.
But Here goes, I purchased this skin
http://preview2.dotnetnukeskin.com/...sl007_BlueI have tried to change the banner image and I am having troubles.
I built the banner image in Adobe Photo shop and set the image size the same.
In the skins folder I deleted all of the original Image Panes and replaced w/ only the 1 that made, which I also named as "Image 1"
In the set up ducumentation for chnging images its Say's
Banner Images
Change Banner Image
The skin pack includes skins with a banner image pane and without.
To replace the banner image you need to change the background image in the #TableImagePane ElementID in the skin.css file.
Add New Banner Image
To add you own banner image you need to upload a new image to the media folder of the skin pack and change the background image in the #TableImagePane ElementID in the skin.css file.
