You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
Modules
DNN DataProvider.Instance() error
Last Post 08/19/2016 9:18 AM by
. 7 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Eriol
02/26/2009 2:45 AM
Good Day! I am beginner in DNN. I just wanted create new module using DNN COmpiled Module. Having started my project without Debugging and having registered as Host->SQL, DNN throws this Error-> Error: SQL is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: C:\dotnetnuke\DesktopModules\Admin\SQL\SQL.ascx.vb(97): error BC30456: 'Instance' is not a member of 'DataProvider'. ---> System.Web.HttpCompileException: C:\dotnetnuke\DesktopModules\Admin\SQL\SQL.ascx.vb(97): error BC30456: 'Instance' is not a member of 'DataProvider'. at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.UI.ControlUtilites.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace --- What i can do? Thanks.
Eriol
02/26/2009 4:24 AM
For normal functionning you must be sure that Partial class SQL inherits DotNetNuke.Entities.Modules.PortalModuleBase. It is first you must do.
Second - change DataProvider.Instance().ExecuteSql(....) with
Data.DataProvider.Instance().ExecuteSql(...) in line 97.
Don't forget to make change s in line 91:
Dim strError As String = Data.DataProvider.Instance().ExecuteScript(txtQuery.Text)
So, this theme could be closed.
DNN MVP
02/26/2009 12:32 PM
Thanks for your contribution!
Joe Craig,
Patapsco Research Group
Complete DNN Support
Senthil
03/18/2009 8:08 AM
Thank you very much
Igna...
Keep posting
Vik
06/24/2010 9:14 AM
I created my custom table in SQL DB and I would like to get data from it from Profile page and Login page. How do I do that? I can not use another Inherits on those pages. Could you please give me example of it? StrMyString = ....(Select ...) Execute?? Thank you.
DNN MVP
06/27/2010 6:09 PM
A very simplistic answer is that you will have to write code that does SQL selects to get data out of the existing tables, and then you will have to write that data into your tables.
If you could provide more details on what you are trying to do, that would help me in giving a better answer.
In general, though, copying data from one table and storing it in another table is considered to be bad design. You only want to have data items stored in one place. That's the whole rationale behind relational database models. The data exists, and is connected to other data via relations. So, what you would be storing in your tables should be indices that reference the actual data values. If you do that, you'll not run into synchronization problems, and all data will always be current.
Joe Craig,
Paco Martinez
08/19/2016 5:10 AM
Hi.
I am attemping to update from 5.6.8 to 6.0.0 and I get SAME error
Install.aspx.cs (71): error CS0117: 'DataProvider' does not contain a definition for 'Instance'
Source File: ....\Website\Install\Install.aspx.cs Line: 71
Line 71: string strProviderPath = DataProvider.Instance().GetProviderPath();
Is there any change critical in this version 6.0.0 ??
Thnks
DNN MVP
08/19/2016 9:18 AM
Try following the recommended upgrade path that is 5.6.8 to 6.2.8, instead of upgrading to 6.0.0.
Also, make sure that you "unblock" the upgrade zip file before extracting the upgrade files.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Modules
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
