You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
DNN Creative Articles
Issue 41 - Auto Merge Method
Last Post 02/23/2009 8:49 AM by
. 9 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
CBOSS INC
02/02/2009 3:23 PM
Unless I'm missing it, I'm not seeing any difference in the videos 2 and 3 that demonstrate the difference between the Auto Merge Method of upgrade and the Manual method of upgrading? Where's the Auto Merge Method?
Also- please delete my post for Issue 40- wrong issue, wrong subject
DNN MVP
02/02/2009 5:50 PM
Short summary:
The Auto-Merge method doesn't require that you copy items from your old web.config file to a new one. You simply unzip the UPGRADE DotNetNuke package into your web directory.
The Manual method requires that you move some items from the prior web.config to the new one. Since it's manual, it is prone to error.
Joe Craig,
Patapsco Research Group
Complete DNN Support
CBOSS INC
02/03/2009 10:41 AM
But you still need to copy over information such as connection strings, app settings and machine keys? So it's still a manual process. I thought that it would somehow merge the contents of my current web config with the update web config
DNN MVP
02/03/2009 11:53 AM
No, the whole point is that you no longer have to copy anything from your old web.config. The "auto merge" part of the upgrade process does that for you. Settings from your old web.config are used in the new one.
Joe Craig,
Dan Whitacre
02/21/2009 12:57 PM
Joe,
Just to be clear, the auto-merge method is not available for upgrading DNN versions prior to 4.6.1, correct? I am upgrading a 4.4.1 install and I will need to make all those changes for a 4.9.1 upgrade....AM I CORRECT?
DNN MVP
02/21/2009 12:59 PM
I think you have to have upgraded to 4.6.2 to be able to use auto-merge for upgrades.
Joe Craig,
02/23/2009 7:09 AM
yes correct - its 4.6.2 onwards that as automerge available
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Dan Whitacre
02/23/2009 7:36 AM
So, is there any reason why I shouldn't just do a manual upgrade to 4.9.1? If not, I think I just need to connect the db in two places (I don't need to mess with the machine key, correct?).
02/23/2009 8:30 AM
You can use the manual method to upgrade to whatever version you require.
However I would test it first before attempting on your live site. You may find you get errors and if you do the solution will more than likely be to upgrade to 4.6.2 first and then to 4.9.1.
If you decide to go straight to 4.9.1, use the manual method as outlined in the tutorial, make sure you copy across the required fields such as connection string, machine keys, installation date, etc.
DotNetNuke Podcasts
Twitter:
DNN MVP
02/23/2009 8:49 AM
I would say that the manual method is more prone to errrors than the auto-merge method.
Also, upgrade to 4.9.2 rather than 4.9.1. That upgrade was released a week ago and fixes some errors in the 4.9.1 release.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
