hello,
okay you can install a module using FTP.
Go to your DotNetNuke installation files and the install folder / module folder
FTP into that folder the skin object zip file.
Then go to a browser and enter:
http://www.yourdomainname.com/Insta...lResources" target="_blank" rel="nofollow">http://www.yourdomainname.com/Insta...lResources
This will install the skin object.
Once you have installed the skin object you will need to reinstall the skin, so if you still do not have access to the admin menu go to:
FTP - install folder / Skin folder
Upload the skin.zip file
This will reinstall the skin
A quick tip - if you are experimenting with new skins, do not apply them to the whole website, just apply them to a single page and then if a problem occurs you will not have problems accessing the admin and host menus.
