Hi Bill,
In Module Configuration, Validation Configuration, you'll find settings that will help you. The ones I use the most are:
1. Validation Summary Location
2. Force User to top or bottom of form after invalid validation
3. Set focus on first validation error field.
Also, when you manage the question, you can add your 'required text' in Question Validation.
Hope that helps. If you have additional questions, please feel free to
send us a note. Thanks!
Candace Santos
Data Springs, Inc.
