I want to add my company details as a link in the footer of my pages in the same way the Terms and Privacy work. I can do this by adding the url into the skin and creating a new a.class to make it look the same as the other skin object items. What I have just tried to do is create a new object and token. I have used the Terms xml, ascx and vb files and changed the code to match my new link. I have had several issues. When I try to upload and install the skin from a .zip i get the following error,
Processing token: [DTC]
Token not found: [DTC]
When I try and put this directly into my ascx file I get this error.
DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.Web.HttpParseException: C:\websites\DNN\cssskin\Admin\Skins\DTC.ascx.vb(1): error ASPNET: Make sure that the class defined in this code file matches the 'inherits' attribute, and that it extends the correct base class (e.g. Page or UserControl). ---> System.Web.HttpCompileException: C:\websites\DNN\cssskin\Admin\Skins\DTC.ascx.vb(1): error ASPNET: Make sure that the class defined in this code file matches the 'inherits' attribute, and that it extends the correct base class (e.g. Page or UserControl). at System.Web.Compilation.BuildManager.PostProcessFoundBuildResult(BuildResult result, Boolean keyFromVPP, VirtualPath virtualPath) etc etc....
Can you point me in the right direction, is it possable to do this in this way?
Regards
Roger
