You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
Skin not recognized
Last Post 07/09/2014 10:28 PM by
. 7 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
sudosonic
12/11/2008 2:24 AM
When I upload the skin it shows no previews saying "No Skin Files Exist in Folder" when I select the skins Skin. It's as if it's not recognized. This happens even if I do no edits. I'm simply unzipping the DNN-Blue skin.zip and then rezipping it, then installing it. What am I doing wrong? It works if I just install the skins.zip file from the tutorial without opening it and rezipping it myself.
Oh also when I do the install, everything looks correct with the install process.
-Paul Duffey
DNN MVP
12/11/2008 7:16 PM
The skins.zip file really needs to be inside of another zip file, and the skin will take the name of the containing file.
The other thing that could be wrong is installing a skin as admin and looking for it in another site, or installing as a host skin, and looking for a site skin.
If you have access to the web directory, look in the Portals directory look for Skins directories in _default and the various portals to see how things are installed.
Joe Craig,
Patapsco Research Group
Complete DNN Support
sudosonic
12/11/2008 9:11 PM
Thanks, I found my answer on another sites forum. What I was doing wrong was I was zipping the folder of the skin, rather than zipping the contents of the folder. By the way, your search function on this forum doesnt seem to be working properly.
-Paul Duffey
sudosonic.com
DNN MVP
12/12/2008 9:06 AM
Can you elaborate on the search problem?
Joe Craig,
sudosonic
12/12/2008 9:30 AM
When I go into forum search, I type in "skins", and almost instantly I get a page of results, then it dissapears and goes to a blank search page. This is in ie7.
12/18/2008 9:52 AM
Thanks for the feedback, I too have the problem, I think it must be coming from the new search module interfering with the forum module.
I will have a look into this, thanks for bringing it to our attention.
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Ron Rushing
07/09/2014 6:26 PM
I purchased a DNN skin and installed it. It is installed but does not show in the site or page skin drop down.
DNN MVP
07/09/2014 10:28 PM
I would suggest that you check with the skin's developer and verify that you installed it correctly. Did you use the Exension installation wizard? Were there any error messages.
If you look in /Portals/_default/Skins you should find a folder with the skin's name. In that folder you should find the .ascx files at the top level. If not, something went wrong during the installation.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
