<!--[if gte mso 9]>
Normal
0
unctuationKerning/>
false
false
false
oNotPromoteQF/>
EN-US
X-NONE
HE
ontGrowAutofit/>
ontVertAlignCellWithSp/>
ontBreakConstrainedForcedTables/>
ontVertAlignInTxbx/>
MicrosoftInternetExplorer4
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;
mso-font-charset:2;
mso-generic-font-family:auto;
mso-font-pitch:variable;
mso-font-signature:0 268435456 0 0 -2147483648 0;}
@font-face
{font-family:"Cambria Math";
panose-1:2 4 5 3 5 4 6 3 2 4;
mso-font-charset:1;
mso-generic-font-family:roman;
mso-font-format:other;
mso-font-signature:0 0 0 0 0 0;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:-1610611985 1073750139 0 0 159 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:"";
margin-top:0in;
margin-right:0in;
margin-bottom:10.0pt;
margin-left:0in;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:Calibri;
mso-fareast-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:Arial;
mso-bidi-theme-font:minor-bidi;}
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
.MsoPapDefault
line-height:115%;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
<!--[if gte mso 10]>
I had followed all skinning tutorials that were very helpful a saved me lot of
time however here's a problem I’m not able to solve with the information there.
I'm building a right-to-left language site and unfortunately it's not as easy
as suggested by issue #7! The main problem with rtl language implementation (after
you overcome the menu one) is that not all texts align to right as they should
be. I already solve a bunch of these cases with tips I learned from dnncreative
videos so thanks, but this one I couldn’t. The problem is with the user’s
profile module where the labels are always displays on the left and the fields
on the right. Using wed developer toolbar (also something I learned here)
I already found they're both encapsulated
within two Div tags that are floated to the left and right respectively. The
problem is that both don’t have an ID so apparently it cannot be fixed by the css.
I thought maybe I could find it in one of the files in admin/users/… in vain.
Is there anything to do, even if it requires changing some code, I'll manage
doing it if I know where it’s.
I attached a pic to show the problem.
I'll really appreciate any help.
Thanks in advance,
OrenG
