Thanks Lee.
https://www.google.com/accounts/ServiceLogin?service=websiteoptimizer&continue=https%3A%2F%2Fwww.google.com%2Fanalytics%2Fsiteopt%2F%3Fet%3Dreset%26hl%3Den&hl=en
Hi Lee
I am testing the “Google Website Optimizer” – (Link above). The General Analytics is a bit different, just one JAVA script for all pages.
This system requires 3 individual pages under the same domain.
I get 2 Java scripts for Top and Bottom of the first page.
One Java script for the second page.
And finally a Java script for the third – so called conversion – page.
I just put the Google / Java code in a Text/Html Module, either an existing or I add a dedicated module for the code. The installation is tested and I get failure or approval before continuing. – So the code should been properly installed.
Using the “skin.html” (assuming that’s where you put the code Lee?) here means I need separate skin for the 3 pages.
I will do another test today, this time on three pages in the same portal.
Cheers
Olle…
