I have done everything your excellent tutorial video says.
I have used AceFTPPro3 and transfered all the files.
I have logged into EasyCGI my host povider, and found all my files in the dnn-folder, I guess the transfer was a succes.
If I understood your tutotial correct the only thing I needed to do were transfer my content from local host to my host provider, and then everything would be public for everyone to see?
I get the feeling that EasyCGI don't have the best DNN-expertise availible. I got an answer late last night saying that my installation was wrong.
My original message to EasyCGIHello
I have developed a site in DotNetNuke - DNN.
I have transfered all the files with the help of my FTP software. Whats my next step so that all my website content can be published and visible on my website mywebsite.com?
regards
Alexander
Got this answer from them...Hello Alexander,
Thank you for contacting Support.
We apologize for any inconvenience this has caused you. I have asked a member of our team who specializes in Web site to review your issue. You should be hearing from this specialist within 24-48 hours. If you have any questions in the meantime, please let us know and be sure to refer to the link
http://www.easycgi.com/member/sconsole for the quickest service.
Thank you for choosing EasyCGI, we appreciate your support.
Sincerely,
Alwyn Dunn
Customer Support
This is their internal discussion + the answer they sent me, witch is public for the customer...How are they thinking? seems to me they are lost and guessing?Reported symphom:
Alexander contacted us saying that he has created the Web site using the
DotNetNuke. He also said that he has uploaded the files to the account using the
FTP and wants the web site to publish. I have checked the account and noticed
that the files are in the folder ‘dnn’.
Diagnosis:
May not be installed correctly.
This is the last answer I got from themHello,
Thank you for contacting us.
I have checked the issue
and noticed that the ‘Dotnetnuke’ is not installed correctly. Please installed
the application from the install central and verify this from your end.
If you have any further questions, please update the Support Console.
Sincerely,
Aleta Meyer
Technical Specialist
I don´t really understand what they want me to reinstall? I thought that after using the FTP all would be public on my www.mywebsite.com
best regards
Alexander
