stylefungus
Nuke Newbie Posts:1
10/13/2008 7:41 PM |
I installed DNN on Godaddy with no problems on the root. Permissions checked out ok but now when I log in and choose host settings I get this as well as an error when I click add page
DotNetNuke Error: - Version 04.09.00
An error has occurred. DotNetNuke.Services.Exceptions.PageLoadException: Exception has been thrown by the target of an invocation. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Security.SecurityException: Request for the permission of type 'System.Security.Permissions.FileIOPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed. at System.Security.CodeAccessSecurityEngine.Check(Object demand, StackCrawlMark& stackMark, Boolean isPermSet) at System.Security.CodeAccessPermission.Demand() at System.Reflection.Assembly.VerifyCodeBaseDiscovery(String codeBase) at System.Reflection.Assembly.get_CodeBase() at System.Web.Handlers.ScriptResourceHandler.GetCodeBaseWithAssert(Assembly assembly) at System.Web.Handlers.ScriptResourceHandler.GetLastWriteTime(Assembly assembly) at System.Web.Handlers.ScriptResourceHandler.GetAssemblyInfoInternal(Assembly assembly) at System.Web.Handlers.ScriptResourceHandler.GetAssemblyInfo(Assembly assembly) at System.Web.Handlers.ScriptResourceHandler.RuntimeScriptResourceHandler.System.Web.Handlers.IScriptResourceHandler.GetScriptResourceUrl(Assembly assembly, String resourceName, CultureInfo culture, Boolean zip, Boolean notifyScriptLoaded) at System.Web.UI.ScriptManager.GetScriptResourceUrl(String resourceName, Assembly assembly) at System.Web.UI.ScriptRegistrationManager.RegisterClientScriptResource(Control control, Type type, String resourceName) at System.Web.UI.ScriptManager.RegisterClientScriptResource(Control control, Type type, String resourceName) The action that failed was: Demand The type of the first permission that failed was: System.Security.Permissions.FileIOPermission The Zone of the assembly that failed was: MyComputer --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams) at System.Web.UI.WebControls.ValidatorCompatibilityHelper.RegisterClientScriptResource(Control control, Type type, String resourceName) at System.Web.UI.WebControls.BaseValidator.RegisterValidatorCommonScript() at System.Web.UI.WebControls.BaseValidator.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace --- |
