Hello Lee,
First, let me say that I love your videos and this is my second year with your magazine.
Your instructions are clear, with details and cover all aspects of the subjects you cover.
You saved me a lot of time and I really appreciate it.
I have a problem with
Issue 32 - Powerful Efficient Techniques for DotNetNuke Administration using SQL
Introduction to SQL Queries with SQL Server Express, DotNetNuke and Vista
I work with Windows XP Pro.
I followed your instructions.
I attached my local DNN484 database to MSSQL Express server.
When I run my local DNN484 I get the following error:
Cannot open user default database. Login failed.
Login failed for user 'USER-2595F5A09E\ASPNET'.
I attached here a screen capture of the error.
Do you know what is wrong? Can you help?
Sincerely,
Nir Petrank
Glad to hear you find the videos useful, it is always good to hear.
This problem may be related to your setup of SQL Server, have you previously installed a localhost installation of DotNetNuke to your computer and successfully got it running?
Your problem that may be related to the server authentication mode, it needs to be set to 'SQL server and Windows authentication' mode rather than 'Windows authentication'
I discussed how to fix this problem in this forum post
SQL Server authentication modeThanks,
