Posted By leesykes on 02 Aug 2006 6:23 AM
Hi Lynn,
I've just tested them and I can download all of the files from both of the servers. - Can you download the other files? Have you tried from both servers?
Hi Lee
Thanks for that suggestion.
I was originally trying to download using IE6 and I was able to download all files except the above mentioned files/video's.
On your suggestion I tried using FF and this time I managed to download the rest of the video's. However, I found that I was required to change the file name before I could unzip them as the length of the name exceeded the limit for my computer.
Thanks.
Regards
Lynn
