I am trying to redirect to a customer build commerce page off a custom login page modified within the DNN login module.I have read that the redirect after login has issues and I too have not had any luck.Would anyone have a solution for this issue ? A) is there a codeing solution and where ould it go.b) is there a patch or upgradeC) Hhy have a option in the system if If it is Broke!What are all the consideration when redirecting (portal settings , User setting, file settings, module settings)thanks
