Crashing the Server:
Yes I ordered the Web Host “Re-Invent Inc” to wipe everything off one of the hostings / servers, including the database, and Install a fresh copy of DNN 04.09.00.
A bit drastic way of upgrading DNN, but this particular hosting was the first one when I started with DNN. There are irrelevant pages, bad design and solutions, non functional E-mails and Web Links, etc, etc…
So, starting with a very clean DNN 04.09, what do I need to do to prepare for a properly functioning and organized server:
I downloaded the HouseMenu which I will install.
I installed skin templates for the new CSS Skins, but never been able to use them.
(Error: template isn’t a proper Dot Net Nuke…..)
I will pretty quickly come up to 10 different Portals, have 5 or 6 Domains pointed already.
Any tutorial that can be helpful?
Considering the DNN is installed, this is only configuration.
Any Hints and ideas?
