Thanks Puuri.
My first thought was that it sounds like Re-Invent.
I believe it’s a very price competitive hosting, but after that they can provide a backup; $15.00 each, Pointing additional Domains, $15.00, you can get extra Database Space $5.00 per month, they can renew your DNN version, $15.00 and you can have extra E-mails $5.00 per month……
When I checked it out I found this one was referring to a third party tool.
I have just downloaded the files through my FTP, takes a bit of time but I haven’t worried about it.
I was more concerned about the SQL-database, I did Lee’s Tutorial about backing up and install locally – I wasn’t able to get it running on my local machine since I didn’t have the database.
Have you managed to get a site running locally Puuri?
It doesn’t seem like the DNN Module backup the SQL database at all ???
Re-Invent does daily backups and are able to restore the site, so that covers a bit of what the DNN module does anyway.
Thanks for the ideas.
Olle…
PS. Joe, this must be the Snowcoverend Module you referred to???
