Thanks for your reply Yesterday Lee.
I will do a new upload and see if I can get the template working.
I’m playing with some different skins, causing problems for myself.
(Believe I slowly get the hang of it, and can sort out the CSS now.)
When I upload several skins on the same hosting (for testing in different portals) they seems to integrate into one “skin” folder.
Also the containers sometimes have the same name?
Am I suppose to rename everything, or at least the “skin.zip” file before uploading?
I want to test Summer Breeze and Zenlike at the same hosting as the 2 below.
Cheers
Olle….
Here’s a version of the “Curiously Green”
http://www.goldcoastwebwiz.com/dotnetnuke/grape
And this is Lazy Days
http://www.goldcoastwebwiz.com/susana
