Hi there
I am trying to create a container with rounded corners without using images. I discovered the Nifty Corners article, and found that it works well with pure HTML files.
You will find the article, here:
http://html.it/articoli/esempi/arti...index.htmlHowever, when I implement the same principles in a DNN container, it only works after you refresh the page (using IE7).
I attached a very simple version of the container to this post, does anybody have any advice or know of any IE7 bugs/reason for the problem - even better how to fix?
The same container works 100% when viewed with Firefox.
Regards
Wadda
